Template for marking wire holes in deck balustrade posts.
Stephen B
[size=13pt]For marking points for drilling stainless steal wire holes in deck balustrade posts; I made this template several years ago. Photographed it when using it again today.
The use of clamp and level allow for minor adjustments when a post may be slightly out of true. Marking can be either with a round led retracting pencil or 1-2mm drill bit. After marking is complete holes are drilled from both sides of each post, and should be aligned within and post to post.
