festoolfan1000
- Mar 22, 2007
Anyone use the Tenryu and can compare it to the Festool Fine Tooth blade?
I understand that the Tenryu blade has a raker as well as an alternate face tooth design. Unlike the Festool with the ATB and straight tooth face to the teeth. I suspect this will mean the the blade kerf will change on the Tenryu after each sharpening.
On the other hand, I believe that one of the reasons the splinter guards wear so quickly with the Festool blade is the straight face tooth design heating up and melting the strip. I frequently have to clean the black residue off the blade. I suspect that this would not happen with the Tenryu which makes me very interested in trying them.
Anyone have both?
Can anyone confirm the difference between the Tenryu PSL-16048ABM2 and the Tenryu PSW-16048AB2 blade geometry specifics are not listed but they appear to be the same?...
http://www.prosawblades.com/products.php?cat=33
Thanks,
Michael
Anyone have both?
Thanks,
Michael
