The Amazing CXS
vwdave
So today I had to go to a job done by someone else that put the handrail on the wall of a pocket door.  They screwed the top bracket into a 3/4" pocket door stud and it finally came loose.  The homeowner did not want the wall opened up and wanted the railing secured.  So I removed the door and glued a piece of plywood to the backside of the drywall and used the cxs and 2 long screws to secure the railing return to the wall.  I was also able to move the railing bracket a little and get that re secured to the pocket door stud.  I had to remove the belt clip from the cxs drill and it fit in the cavity perfectly.Now this wasn't what I wanted to do but the homeowner is always right when they pay so.  I told them to add a full length handrail on the opposite wall and we can leave the other one for looks  [tongue].
[attachimg=#]
Lets see some other cool pics of the CXS at work.  I love this little drill.
Dave R
Dave,
Couldn't you just drill a pilot hole diagonally from underneath the handrail into the start of the stud and drive a long deck screw or lag in through the handrail into the stud?
There is no stud at the top of the stairs. The return falls in between two 3/4" pocket door studs. There is a bracket 4' down into the box. All air the rest of the way.
Dave
The cxs is amazing and there's been a million times i've needed it in a space just like that. Of course I'm not allowed to take pics at work AND IT KILLS ME!!!!! but rest assured it is amazing!!
Here ya go.  Had to remove some deco door panels on an island so I could have them refinished.  Unfortunately, there was a cooktop in the way...no problem.  Grab the cxs, and done.  I could have used my c12, but its much heavier, a little bigger would have been more awkward.
Jon
The CXS also works well to pound in small trim nails.
Does not leave as big of a mark as my C-12. [big grin]
