The Best Just Got Better: TSO Parallel Guide System... Gen 2
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Track saws excel at making smooth, straight and clean cut, but struggle with repeatability without some assistance. Parallel guides are to a track saw what a rip fence is to a table saw - a reliable means of making cuts at a given width.
A favourite of track saw users everywhere, the TSO Products Parallel Guide System (PGS) has been further improved with Generation 2. Based on user feedback, every detail has been re-engineered for ease of use, precision, and reliability. See why the new TSO Parallel Guide System Gen 2 continues to lead the way.
  • Fastest Setup: Drop-Loc Connectors quickly install anywhere on your guide rail with a tilt and button press. Compatible with Festool, Makita, Milwaukee, Kreg, Ridgid, Powertec and Wen.
  • Accurate & Reliable: New Flip Stop Pros are rock solid with zero deflection, zero parallax, and a calibration system that holds true. Two come with every System, and extras are available separately.
  • Clear Vision: Connection the PGS to a Guide Rail Square allows you to make square crosscuts and parallel rip cuts with the same setup. The new connector allows improved visibility of the reference surface of the square.
  • Safe, Accurate Narrow Rip Cuts: Rip cuts narrower than the guide rail are challenging with a track saw. No longer. With the Narrow Stock Pro accessory, thin cuts are safe, accurate, and repeatable. (Works with PGS Gen 1, too.)
  • System Organization: Choose from two foam Systainer inserts to keep your PGS System components safe, organized, and easily accessible.
Whether you’re breaking down sheet goods, ripping long panels, or making tricky narrow cuts, the new system gives you unmatched control and confidence.
And with backwards compatibility, you can bring your favourite TSO accessories — including the Flip Stop Pro and GRS-16 Guide Rail Square — right into your upgraded setup.
This is the most advanced TSO system yet. Are you ready for it?
Get the TSO Parallel Guide System Gen 2 Now
