Sean Ackerman said:Shane, is that the super fancy new camera you were telling me about? [tongue]![]()
Shane Holland said:Sean Ackerman said:Shane, is that the super fancy new camera you were telling me about? [tongue]![]()
Feel free to post a better photo. Oh... wait a minute... you don't have the new drills. [poke] And, it seems that your order for them just got placed on hold indefinitely due to some anomaly in our system. [popcorn]
Sean Ackerman said:But oh, I've got drills you don't have (imagine a smilie poking a smilie with a much bigger stick here). And that preorder is soooooooo approved. [eek]
Oh Shane, that's so cold...Shane Holland said:Sean Ackerman said:But oh, I've got drills you don't have (imagine a smilie poking a smilie with a much bigger stick here). And that preorder is soooooooo approved. [eek]
Oh, but I DO have those drills too. Welp, it's 5pm, time to go home and cut some stuff on my CMS. Then assemble it on my Vac-Sys using the Domino XL.
WarnerConstCo. said:Will I have to keep them in a sweater for the winter?
I know how Lithium Ion feels about the cold weather.
Shane Holland said:WarnerConstCo. said:Will I have to keep them in a sweater for the winter?
Darcy, I know that you've wanted the answer to that question and even asked it when you were on the phone with Rick today. I don't have the answer really. I got specs at some point and posted them here or on talkFestool (I don't remember which) for the suggested temperature ranges for the batteries (or maybe I didn't [huh]). The best thing to do would be to hit up some of the guys on the forum who have the T-drills to see how their batteries have performed in the cold weather.
Brice Burrell said:I can tell you they don't the cold much. They work fairly well in moderate temps but when it you gets much below freezing the performance drops off pretty quick. If you keep them from getting too cold and keep working they'll be fine. If you leave them in the truck over night in the winter you'll likely be disappointed in the morning. Throw them on the charger to warm them up and keep the battery inside or in your pocket if you're not going to use it for an extended amount of time.
Getting the job done and getting paid is a good enough reason to give up some charge cycles.WarnerConstCo. said:Brice Burrell said:I can tell you they don't the cold much. They work fairly well in moderate temps but when it you gets much below freezing the performance drops off pretty quick. If you keep them from getting too cold and keep working they'll be fine. If you leave them in the truck over night in the winter you'll likely be disappointed in the morning. Throw them on the charger to warm them up and keep the battery inside or in your pocket if you're not going to use it for an extended amount of time.
That is the part that I am not sure about. It seems there is only a certain number of charge cycles a battery can endure and just popping it on the charger to warm it up seems to count as a charge cycle to me.
