- Jun 25, 2016
[size=18pt]Our best-selling, five-star rated TPG-20 Parallel Guide System is compact enough to fit in a Systainer, so it's only natural that we now offer a custom Kaizen foam insert to house and protect your kit!
Now through Sunday, use promo code FOG223 to save 10% off this insert, as well as our TSO Limited Edition Blue Systainer!
We built the patented TSO Parallel Guide System from the ground-up to offer the most capability and accuracy—and to specifically address user-reported limitations of competing products. Like all parallel guides, this system provides for repeatable rips—but it has a few distinct qualities you’ll only find from a TSO Product:
* No cumbersome designs that rely on sliding together small tracks and time-consuming setup. Only one-piece T-tracks with rock-solid bolt-on attachment to your guide rail, a FlipStop v2.0 that only moves when you want it to, and lightning-fast calibration.
* Metric and Imperial dual dimensions are laser engraved on every T-track because…why not?
* Exclusive Calibration Memory™ feature of FlipStop v2.0 removes the need for re-calibration when changing between standard and narrow stock rods.
* Longer T-Tracks available with capacity to rip full 4x8 sheetgoods all the way down to very narrow cuts, with material as thin a 1/4" (6mm).
Learn more about the TSO Parallel Guide System.
Here's a few of our most popular products:
JUST RELEASED! MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
20mm Bench Dogs and Dog Stops
We have a dog for every job! Grab a pair for basic work holding or one of our exclusive Power-Loc and Smart Connect bench dogs—perfect for expanding your worktops or securing jigs and fixtures.
GRE-13 Guide Rail Extension
Provide more support at both ends of your plunge cuts with this 13.7-inch (346 mm) guide rail extension, which conveniently fits in a Systainer. Connectors included!
