Thermaltake BigWater 760i Liquid Cooling System
Status
Not open for further replies.
nickao
SOLD
Great for a computer or liquid cooled router or spindle - Designed for a PC and to take up two bays. I suppose you can mount it externally as well, just not as nice that way.
Thermaltake BigWater 760i Liquid Cooling System - I was going to use it for a 3KW water Spindle and never did.
This has everything you need and I believe if you mount it on the X the included hose may be long enough. Would be really neat using it for a water cooled spindle and of course you can water cool your PC with it too. I totally forgot I had it. As I was cleaning came across it new in the box, the tape still is sealed on the package. I will crack it open to make sure everything is still pristine. where you see in the picture below the two hoses go to the CPU mount, just take that out and connect the two hoses to the spindle. Radiator, fan and tank all self contained.
This is the best price I could find, 144.99 plus shipping. It looks like it gets some decent reviews here:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=3302740&SRCCODE=PRICEGRABBER&cm_mmc_o=2mHCjCVybgwTyz__wyCjCVqHCjCdwwp&cpncode=25-11522211-2
I have a feeling as I clean this weekend I may find some more stuff for CNC, woodworking and computers, I will post as I find it.
ThermalTake Big Water 760i:
Liquid Cooling: Water Blocks - CPU
Fan Size: 120mm
Bearing Type: Ceramic Bearing
RPM: 1600 ~ 2400 RPM
Noise Level: 16 dBA
Heatsink Material: Aluminum
Voltage: 12 V
Connector(s): 4-Pin
Heatsink Dimensions: 153 x 120 x 28 mm
I will sell it for 120.00 including shipping( I pay the shipping of 15.00 to 20.00).
Life Hours: 80,000 Hours
Reduced to 110.00 including shipping
Status
