Brice Burrell
- Mar 13, 2007
Thoughts on sanding drywall with a Festool sander.
I used my DTS400 to sand drywall compound in a 15' X 15' room (with a lot of windows) last week and here some of observations. But before I get too far into this I should first mention that drywall compound dust is very fine so it can be harmful to tools used extensively in this application. I wouldn't recommend sanding drywall compound regularly with sanders and vacuums not made specifically for this task. However, occasional sanding with Festool sanders and vacs should hold up just fine.
I used 120 grit Brilliant 2, I would have preferred 150 grit but I didn't have any with me at the time. I had the suction turned down fairly low for sanding the walls, a bit under 1/4 power, so the sander would glide nicely across the surface. The sander moved freely but the dust collection wasn't bad but not great either. I'd guess maybe 70% of the dust was collected. While this was a big improvement over hand sanding with no dust collection it wasn't good enough to sand without being concerned about the dust migrating throughout the work space and beyond.
For the ceiling I turned the section up to about 1/3, the increased suction helped hold the sander up to the ceiling to some small degree. Dust collection improved to about 75-80%. Managing hose was certainly more difficult sanding the ceiling but doable. I pretty much needed to hold the hose with one hand and the sanding with the other to keep the dangling hose from pulling the sanding off the ceiling. This limited my reach somewhat since I couldn't extend far hanging on the ladder and managing the hose. The upshot was I didn't end up with a face covered in dust.
The sander makes quick work of drywall compound so you really need to keep the sander moving briskly to avoid sanding through to the tape or over sanding the paper. In fact, I'd be so busy keeping the sander moving I couldn't focus my attention on the quality of the job. I had to stop sanding to carefully check out areas to make sure they were sanded adequately. Managing a ladder, light, sander, hose, vacuum and power cords isn't always easy with two guys working in a small room.
The challenges I run into were holding the sander flat (more so on the ceiling than the walls), managing the vac/hose and aggressiveness of the sander. The advantages were, dust collection and sanding easily in corners/edges. For this particular job there was no significant advantage to using a power sander over hand sanding. No real time or effort saved, the improvement dust collection wasn't important and the quality of the job wasn't any better. I would bother with using a power sander again unless I was sanding a small area where dust collection was important.
Since most guys are used to using a pole sander the quality of the job is probably the same. On my job the room had a lot of natural light coming through the windows so the drywall needed to finished and sanded well to not see imperfections so this job wasn't ideal for a power sander. I might have been better with a hand sander carefully sanding with a light in my free hand to spot any imperfections. For the average job a Festool sander could save some time and effort over hand sanding once you develop your technique for the speed of the sander and managing the hose. My advice for those wanting to try your Festool sander, 150 grit paper, play with the suction on the vac to find a good balance between dust collection and sander movement.
In the end I was a bit disappointed given the rave reviews of others on this forum. I by no means started this discussion to talk anyone out of trying this. I welcome comments and suggestions.
