semenza
Saw in another thread that someone was having to deal with removing old, painted in slotted screws. Here is a trick I picked up from somewhere else (don't remember where), might have posted it before but ......
Use an abrasive cutting disk in a Dremel or similar rotary tool to clean the old paint out and renew the slot. Just ease the edge of the cutter in, parallel and perpedicular. Move it back and forth a bit and you will have a like new slot. I have done this quite a few times and it has worked without fail. Might seem like something extra to do but it works so well that it is much quicker and easier especially if doing more than a couple.
Be careful not to go too deep and split the screw shaft.
The angle head for the rotary tool can make it easier to align in many cases.
