Deansocial said:i want to try the heco srews. JMB and I were talking about them the other week and they self drill in 2mm steel and will tap into concrete aswell, looks like a a good allround screw
Alex said:Deansocial said:i want to try the heco srews. JMB and I were talking about them the other week and they self drill in 2mm steel and will tap into concrete aswell, looks like a a good allround screw
I mostly use Heco too, very good screws. I'm not sure about what you said about steel and concrete there though. I never noticed they could do that.
MarkusS said:Deansocial said:i want to try the heco srews. JMB and I were talking about them the other week and they self drill in 2mm steel and will tap into concrete aswell, looks like a a good allround screw
I use (almost) only the Heco Unix and Topix screws and I'm very happy with them. At least as good as the Spax-Screws but cheaper.
If you want some samples I can put some Hecos in a envelope an mail them to you.
Regards
Mark
Deansocial said:Alex said:Deansocial said:i want to try the heco srews. JMB and I were talking about them the other week and they self drill in 2mm steel and will tap into concrete aswell, looks like a a good allround screw
taken from the heco site, be interesting to try that type out
"HECO-FIX-plus - The smart, patented multi-material screw
The newly reworked version of the HECO-FIX-plus multi- material screw is ideal for use in all natural and industrial wood-based materials, as well as in masonry, plastic and metal sheets up to 2 mm. A comprehensive product range offers the ideal screw for any application.
The HECO-FIX-plus screw has our patented toothed thread at its point. An extra antifriction coating means minimum driving torque. Ideal for transmission of high tensile loads. It is also possible to undo the screw safely and smoothly at all times. Suitable for screwing through thin metal sheets up to 2 mm thick (e.g. sandwich elements)."
