Peter Halle said:
duburban said:
Anyone still know how to hydrate and mix lime plaster?
I have plenty of experience w/ lime based venetian plaster but never done a from scratch. I'd like to retrace some of the historical mixes (minus the horse hair) and do a cement modified lime plaster with marble agg or super fine sand, maybe with a bonding gyp board base.
Ideas? Plaster geeks?
Perhaps [member=550]Tinker[/member] can help.
Way back when I was just out of high school, I got a job as an apprentice (translation: gofer) mason. The main part of my boss's trade was stone work. At some point along the way, we got involved with plastering. "Brown coat" base was, except for the material used, just like stucco that we did over foundation, mostly over blockwork. the brown coat had to be mixed perfectly every time. That was usually my job.
Eventually, we got into "White coat" that was even more fussy. The boss always mixed that material. For Brown coat, we (I) used a big "mortar tub" was dumped one or two bags of plaster into which water was added as plaster and water was mixed with a very large hoe. that hoe was at least four or five times larger than your every day Home Depot garden hoe that most are familiar with today. The water had to be added at the very start in just the right amount and mixed very quickly. to just the right consistency and with no lumps. That was an easy job compared to mixing of white coat.
For white coat, we used "Unslaked" white lime. That had to be handled with care. Water was poured into the same sized mixing tub as the brown coat had been mixed in, but never the same tub. Then the lime was added very carefully. Never put the lime into the box first and the add the water. I you add the water to the lime, there could be an explosion and any bystander could be badly burned. Whenever using unslaked lime, we always had a bottle of caster oil in our pocket. A burn from a caustic source can be as dangerous as burn from an acid source. The castor oil was to immediately flush out an eye if the lime had splashed onto a face. You did not wait for a doc or want to be spending precious seconds searching for a first aid box, you just reached into your pocket and poured castor oil into your eyes. Fortunately, nobody in our crew ever had to do that. BUT, we were always prepared.
I usually did the mixing of the hot lime. I would mix up enough at the end of the day for tomorrow's project and it would be left in the tub overnite. We had a big sheet of plywood that we did the final mixing of the white coat on. i never did that part, my arms had been cut off at child birth, or my grandparents had been small, or some sort of excuse, I could not reach across that board to do the mixing. The slaked lime was placed on the mixing board. A container of "plaster paris" (you can get hat stuff in hobby shops. It is not dangerous to use.) At this point, I did not get involved. The boss always handled the final mixing. Slaked lime was placed into a big donut into which he plaster paris and water ws dumped. Then the batch was mixed by hand much as my wife later in my days would mix ingredients into a bread dough when needing the dough to make bread. By hat time (back to the mixing of white coat plaster) the lime was supposedly not any more dangerous. We still carried our bottles of castor oil (at least I did) just in case. once the final mixing had been completed, the batch was fed to the plastering crew. and applied in very thin coat to go over the brown coat.
By the time I had advanced to the point I could apply white coat to finish the job, a new invention came along that made all this typing to have no more meaning than if I were typing a story about dinosaurs. I suppose somewhere in this world, somebody is still working with brown coat, hot lime and white plaster. The last time i did a repair to white plaster, i cut into the plaster and wood lathe, replaced with a piece of sheet rock and troweled on joint cement. Three coats of joint cement and one was left with no clue that a repair had ever been made. I much prefer that method to the ancient methods I grew into the trade with.
Oh, BTW, all that was when I was only ...... I can't remember how long ago. Must have been when I was 38.
Tinker
A little side note: yesterday, I got stuck with my snow plow and had to get dragged out. While being dragged out, three of us were working together. I was operating the shovel with the hickory boom, my grandson was driving my truck and my son was driving the truck that was dragging my truck out. Three generations of snow plow guys working together in a snow storm. You don't see that sort of foolishness very often. And, the old f--- was the only one who knows how to use a shovel. The younger generation is definitely smarter.
