Distinctive Interiors said:Plugging in the 110v transformer will trigger the auto start function straight away. It will not matter whether you have a tool plugged into the transformer or not.
DeformedTree said:If a tool isn't plugged into the transformer with it's power switch activated no current will flow thru the transformer.
DeformedTree said:Distinctive Interiors said:Plugging in the 110v transformer will trigger the auto start function straight away. It will not matter whether you have a tool plugged into the transformer or not.
Do you know that from experience? I don't see why that would happen. If a tool isn't plugged into the transformer with it's power switch activated no current will flow thru the transformer. If there are other electronics in a transformer (thus it's more than just a transformer), then maybe it would trigger the vaccum.
Bohdan said:[member=10147]jobsworth[/member]
The question was what happens when you plug the tranny into the CT.
In your case you plugged the CT into the tranny which is a totally normal operation.
