tjbnwi
- May 12, 2008
If I'm parking the sprayer(s) for more than a few days I use pump protector to treat the unit(s). Problem was always wasted treatment product. I solved the problem by creating a narrow vertical vessel instead of using a bucket.
It's simply a 3" diameter 16" tall piece of PVC pipe glued to a closet flange that has the test cap molded to it.
I have 5 gallons of protector mixed up. I set the pick up into the pipe, filled half way with protector is enough to treat the 395AAA or the Merkur. Both have 25' hose sets on them.
No more wasted mix.
No more wasted mix.
