ear3
- Jul 24, 2014
I got a TS55 REQ from the recon sale. I was in the middle of a job, so I immediately put it to work finishing off some straight cuts on veneered plywood panels, which it did no problem.
Once I got it back home, I started using it for some mitre cuts on a cabinet I'm building, and I ran into some issues. I was getting some deflection at the end of the 45 degree cuts, with material left to the right of the scribe line. I soon realized that this was because the blade at the front of the saw was set slightly above 45 degrees. I had been treating it like my TS75, and assumed that once I hit the positive stop everything was good. But on the TS55, the positive stop only operates at the back of the saw -- on the front, because you have the option of going to 47 degrees, you have to visually set it exactly to 45. Once I realized this the subsequent mitre cuts were fine.
Here's my question: When I put the saw back to its resting mode for straight, 90 degree cuts, I saw that the angle indicator is actually around -.3 to -.4 degrees. To hit true zero I have to tilt it ever so slightly to the right and then tighten. Is this the case with everyone else's saw, or has mine (as a recon-ed tool) traveled a bit further down the road from the original factory settings? From what I can see, even though you have to disengage the positive stop at the back of the saw to get all the way to the -1 degree option, because there is no positive stop at 0 at the front, you can't simply tilt the saw back to its resting position and assume you are dead on accurate at 90.
No biggie if that's the case, but it just seems like a weird omission on the part of Festool engineering not to have corresponding positive stops at the front of the saw.
