Curious if the TS 75 handle and motor housing are identical in size to the TS 55?
I ask because I was using a friend's TS 75 and noticed the allen key does not fit in the handle holder like on the TS 55? The metal body which houses the blade is in the way and keeps one from sliding it inside the holder. On the TS 75 it seems as though there is some kind of holder on the base plate to house the key.
Is this because the TS 75 and 55 share the same motor housing and handle, despite, the larger blade and housing of the TS 75 protruding upward? I compared the two visually and despite one saw being larger the parts look nearly identical.
Both are older models I believe. However I don't remember the exact models or years.
