Part 1:
I've been working with harder solid lumber lately and it may be time to give my 36 tooth'er a rest; at least for ripping down boards. Here is my thought process (I'm using a TS 75:
- struggles while cutting 6/4 and 8/4 hard maple and the like
- feels like an eternity to get to the end of ~2700mm of rail
- leaves burn marks on both the sides of the cut
My question(s):
- Is the Panther blade (493 196) the right blade for the resolve the above? If not, then which blade?
- Will the Panther or recommended blade provide a clean, join, and glue ready cut?
- Or am I just doing it wrong? Which could very much be a possibility!
Part 2:
Does the TS 55 REQ's supplied blade (48 tooth) provide a better and cleaner crosscut than the TS 75's 36 tooth? My thought is that after springing for a 52 tooth blade for my 75 and another FS-1400/LR 32 rail, I might as well grab a TS 55 REQ!!!
I would use the 75 for solid lumber and rip cuts and use the 55 on the for sheet goods and cross cuts on the MFT.
My question(s):
Part 2:
