I'm lazy. I admit it. I'm sick and tired of lifting the saw off the track between cuts. So here's a little garage thing I cobbled together. Let's you leave the saw on the track between cuts.
[attachthumb=1]
[attachthumb=2]
I just clamp it down to the end of the track. I keep a 55 on for crosscuts in the other direction on the MFT so I decided to utilize the extra space.
[attachthumb=3]
A nice feature is that you can balance the track half way up. Now I rarely lift it all the way up during a cutting session.
[attachthumb=4]
The way it counter balances you can push the saw through the cut and go ahead and lift the guide with the hand that's holding the saw in one fluid motion. In fact you can cut a piece, dock the saw and lift saw guide and all just with the saw handle, remove the piece, put down another piece, grab the saw handle, lower and seat the guide leveraging the saw handle, slide the saw back to the start and make the next cut. All without ever touching the guide.
Obviously no part of the stock system was designed with anything like this in mind but I've tried it for a couple of days and it seems to work.
[attachthumb=1]
[attachthumb=2]
[attachthumb=3]
[attachthumb=4]
