When mounted in the CMS (or Basic) module, the trigger of the TS55 is locked in place by a C-form clip. With the trigger locked, you can operate the saw through the mainswitch on the CMS table. After switching modules recently, I found that the C-clip was too loose. Pushing the mainswitch on did not start the saw.
Following the power from source (wall socket) to the saw, I found the disengaged trigger on the saw. With a little fumbling the trigger was locked again, but I will make a new C-clip from a scrap of aluminium. To my opinion, this plastic C-clip is rather thin and will creep open over time. It should be reinforced to live up to Festool standard.
I will send a message to the Dutch Festool rep.
Anybody else having this problem?
