lasttoleave
- Feb 8, 2015
Hello,
I've been cutting up some full sheets of MDF/Ply recently and I've noticed an issue that I need to rectify as it will affect the future accuracy of my cuts using the TS55.
Using my 1400 rail, I've noticed that splinter guard is not perfectly flush with the cut edge in places, meaning that if I leave the rail clamped to the material after a cut, there's a small lip between the edge of the splinter guard and the edge just been cut. It seems to be dead flush at the beginning of the cut but the inaccuracy starts about 1/3 of the way and continues up the rail. It's definitely less than 1mm, but it's a lip you can easily get a fingernail on. I cannot see a reason why the splinter guard would be flush at the start of the cut but ever so slightly off at the end?
Thing's I've checked;
-There's no movement in the rail itself (clamped using festool clamps in the t-track)
-The saw has been well adjusted to the guide rail profile, if anything it's on the snug side so no excessive side to side movement.
- The cut edge is near perfect, there's nothing to suggest the saw is cutting badly or any unwanted blade movement.
I'm going to need to calibrate a set of Precision Parallel Guides from the splinter guard edge soon so getting the splinter guard "zero clearance" is essential.
I have a spare splinter guard but I want to see if anyone has some advice before I cut a fresh guard and potentially waste money if it performs exactly the same.
