Out of Square
- Dec 31, 2020
New saw question,
First I have to say that I am new here and I have been wanting a track saw for some time now.
Finally after much research on the subject (and Christmas fast approaching) I was able to put the money together and get a new TS55 with 2-1400mm rail, connectors and a couple of clamps for Christmas.
After looking on the net I was quickly forwarded to this forum in the referrence page.
Now for my quesiton: squaring the blade relative to the base,
(I came across a few reviews/ concerns with the blade not being at 90 degrees out of the box)
I checked on you-tube and only found a couple of referrences where you need to remove the blade cover then check it.
I removed the blade cover and checked it on a known flat surface ( table saw top) and found it to be at 89.5 degrees - Using a Wixey digital gauge.
I did adjust it to 90 degrees while on the flat surface.
My question is should the saw be checked while on the track or on a flat surface? ( both???)
I am thinking there may be some tilt in the track that festool may/ or is accounting for in the set up at the factory.
Also I have not trimmed the splinter guard yet because I want to make sure I take into account all the information on getting the blade square first. [eek]
Thanks in advance.
Thanks in advance.
