I had a go cutting some bevels today with the TS55 which did not go as expected. I wanted to make a mitred box construction to form the sides of a very simple pull-along wagon for my son. I set the saw to the 45 degree mark which to my eyes looked exactly aligned to the 45 degree mark and the corresponding arrow. When I later assembled, all my corners had gaps outwards towards the external corners. Please see images attached. I have no way of actually measuring and determining the accuracy of the saw and haven't noticed anything untoward at the zero position; having said that I haven't cut through anything thicker than 22mm yet so hard for me to gauge 90 degree squareness over such a small reference face.
I am prepared to accept that this could be something I am doing wrong –– I am a novice and new to the saw. But if not, is this typical of the accuracy one can expect for cutting bevels with a tracksaw? I fully understand that the right tool for the job would be a sliding compound mitre saw.
Any advice on how to improve this for future projects and are there any other options I could consider that would give me more precision? Could this also be performed by first cutting the lengths square and then using a 45 degree chamfer bit to router the bevel in order to achieve accurately mating corners? It's not a problem for now but when I start doing more furniture-based projects in more expensive materials I would want better results.
On a separate but related note, I've also attached an image of some splintering I was experiencing when cutting. The offcut side was clean but the 'rail-side' was left with splinters. I'm using the 48t blade, the green splinter guard attachment, and have tried cutting at different speed settings but was getting the same result. Is this down to the fibrous nature of the timber or is there something I should be doing to achieve cleaner cuts?
Thanks for any help
Thanks for any help
