Just an interesting note about the (or mine at least) depth of plunge (cut) indicator on the TS 75:
When adjusted to a setting of 22, the actual depth of blade extending below the base of the saw is 19.03 mm.
Why is this important to me - or others? With the TS 75 and I suspect other plunge saws as well, I try to cut into the table surface only to the depth needed to "cut" off or remove the waste. Since I am cutting across 2 joined MFTs I don't want to either cut thru the tops nor into the aluminum side extrusions, and I don't want to unduly weaken the top by making deep cuts.
Several measurements along different spots on several different rails gives an average rail thickness of 4.76 mm (next to the splinter strip). There is also a space of a few mm that the saw blade must be plunged before it becomes flush with the base of the saw; then the additional space before the blade becomes flush with the surface to be cut; the the thickness of the material being cut, topped off by an additional 2 or 3 mm to ensure a through cut.
So, my point, I guess, is this: I bought into the whole Festool marketing gambit - a system, work smarter, faster, more efficiently, etc., BUT the depth of plunge (cut) indicator on the TS75 (or mine at least) does nothing to affect the system approach.
This isn't a rant against Festool, just trying to point out something which should, in my mind, be improved.
