Greentechnic
- Feb 28, 2016
I have tried everything to remove the bolt in order to replace the riving knife in order to insert the cms riving knife when inserting the saw into the cms module. Heated the bolt, stripped the bolt, inserted a stripped bolt remover which also broke off inside the bolt, 2nd last option is engeneering works before i order a replacement part, truly disgusted with festool at the moment. Just thought i warn anyone else to be careful when they have to do the same, found another thread where a guy battled but seems his was not bonded to the steel as mine
