gordonpeterson
- Nov 12, 2014
I am trying to make a mitered rip cut with my TS75. To do this I am just setting the cut angle of the saw to 45 degrees. The first time I did this it took a huge chunk out of my splinter guard [sad], so I tightened my tension adjusters for the track to take out even the slightest of play (it cuts beautifully at 0 degrees with no problems). I grabbed my other rail and did a small test cut and see if that made a difference. Sure enough it cut the splinter guard down right to the aluminum track [mad]!
grrrrrr
Two splinter guards down and those puppies are not cheap. Has anyone else had this problem? Am I missing something? Is there a solution?
thanks,
-gordon
grrrrrr
thanks,
-gordon
