TSO Extended Miter Fence: Built for Precision, Designed for Efficiency
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Take your CSC SYS 50 to the next level with the TSO Products Extended Miter Fence and Supporting Stop: a compact, versatile upgrade that brings precision, repeatability, and support to every cut.
  • Includes two 300 millimetre aluminum fence sections that can be used separate or combined for extended support
  • T-slots on top and rear for attaching stops, clamps, and accessories
  • Dual-function stop block works as a length stop or support rest
Whether you're needing repeatable crosscuts or support for longer workpieces, this fence upgrade will help you achieve better results—faster, safer, and more efficiently.
Pre-Order Now
That photo should be retaken as the fingers are clearly too close to the line of fire.😬
