Hello
Very quick question, I hope the wealth of knowledge here can help please…..
I’ve just bought the 30” & 50” parallel guide set and a guide rail adapter from TSO having already owned the Festool branded TSO rail square.
Anyway, when tightening the knobs with the centering washers to affix the guides to either the square or the adaptor I expected the guides to sit fairly square to the rail and this isn’t the case.
I know the rail square itself is there to ensure a 90 degree cut so is there a problem if the guides don’t sit square?
TLDR….
Should the knobs with the centering washers pull the guide close to square when tightened or do you have to square them manually each time you change guide lengths?
Many thanks
TLDR….
Many thanks
