- Jun 25, 2016
Sun's out, saws out! Whether you're firing up the grill or cranking out your next project, now’s the perfect time to gear up and save during our Primetime Summer Savings event.
We’re serving up:
* 10% off TSO Products gear
* 5% off UJK & Axminster tools
* Free CONUS shipping on orders over $99
Act fast—this sale wraps up July 15 at 11:59 PM Eastern, and discounts are limited to stock on hand.
Visit TSO Products
Here's a few of our most popular products:
JUST RELEASED! Narrow Stock Pro Rip Cutting System
Designed to reliably cut stock narrower than the guide rail itself, Narrow Stock Pro makes it easy to tackle face frames, edge banding, trim pieces, drawer parts, spacer blocks, and more. It’s the next best thing to a cabinet saw or bandsaw—compact, accurate, and ready to go wherever your track saw takes you.
JUST RELEASED! Multifunction Workbench Fence & Stop Set
Featuring laser-engraved imperial plus metric scales for exceptional accuracy, a robust dual-arm flipstop for reliable and repeatable cuts, and a versatile design that can be mounted upright or flat to suit your needs. Made in the USA from 6061 aluminum with a durable blue anodized finish, the TSO Multifunction Fence installs quickly onto the Festool MFT/3® or any worktop sharing the popular 20x96mm hole pattern. Now available with engraved scales supporting either 900mm (35.4") or 1,200mm (47.25") total cut capacities.
Upgraded Rip Fence for DeWalt 10" Jobsite Table Saw
Designed to take your DeWalt jobsite saw to new levels of precision and versatility. With a triple T-slot design, you can easily mount stock guides, feather boards, sacrificial fences, or custom jigs to make zero-clearance cuts, add new functionality, and keep your workflow smooth. It retains all the original features of the stock DeWalt fence while offering a big jump in capability, and it's easy to install since it uses the existing DeWalt brackets and hardware.
MFT/3 Router Table Extension
Simplify your workflow with a router table extension purpose-built for the MFT/3. The flush-fitting design enables you to use the large work surface of the Festool MFT/3 as router infeed/outfeed support, helping you maximize your workspace and productivity. Compatible with the most popular trim routers on the market.
MFT/3 Extension Table
Expand your Festool MFT/3 work surface by 33%! This extension utilizes three precision machined brackets that quickly lock into the MFT/3 perimeter extrusions to provide a rigid, seamless extension of your worktop. The MDF top is CNC-machined and shares the same 20x96mm hole pattern as the MFT/3, ensuring compatibility with all of your workholding accessories.
GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
