I just took delivery of my new TS55 EQ and MFT/3 package and in the process of setting up the table ran into the instruction that says I need to tune the saw to the track. Placing the saw on the track I see a slight bit of looseness that I want to correct. The illustration shows using a screw driver on the saw but I assume that was a previous model. My new saw has two green knobs that I think are the adjusting points but the saw manual doesn't really address this point. I guess. I need to make this change before I cut the splinter guard. Could use your help and thanks in advance. I want to do the setup right.
