UG Cart weight
cabinetman803
I am looking to purchase the UG stand for my Kapex.  How much does the actual cart weigh, minus the wings.  I'm trying to figure out the total weight of the cart+saw.
Thanks.
10.1 kg for the cart alone, 21kg with the wings. I think this is including package, but that is carboard and some styrofoam.
20.61 pounds for the stand, add a couple of pounds for the two brackets that get bolted to the Kapex.
The Kapex UG Mobile Base is 22.3 lbs (10.1 kg). In case you need it, the shipping weight is 29.7 lbs.
As others mentioned, the entire Kapex UG Set is 46.3 lbs (21 kg).
Just as well it has wheels too as it is a beast to cart around a construction site.  They really should make the wheels a lot wider to give better purchase over sand.
