what size and type transformers do you guys use?
atm in using a 3.3kva tranny which is ok for using a few tools but when im using the of2200 with the ctl 26 im on the power limit and the transformer trips, it has a cycle rating of 5mins on 15mins off which geta rather annoying when using the cms or routing worktops.
some goes when using the kapex for dadoing door frames etc
ive looked at 5kva trannys which are way too heavy to lug around (38kg) but i will have the same problem of tripping because it only has a 2.5kva continous rating so i wil be in the same 5mins on 15 mins off duty cycle
anoyone else have these problems?
