Ultimate Tools - 12 Days of Tools Promotion & Giveaway
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Hello FOG!
12 Days of Tools starts today!
Each day we will feature a different tool on sale for 20-35% off.
Check back daily to see what we have in-store. On Dec. 13th we
will be giving away a tool valued at $99.95! Giveaway details below.
[attachimg=3]
Today's Tool:
Woodpeckers 300mm Precision Woodworking Square for only $134.95 (20% off)
- Machined from cast & ground plate for exceptional accuracy
- angle tolerance within 0.00085
- 300mm longest side
- Laser engraved scales
Deals ends tonight at 11:59PM PST.
Purchase Yours Here
[attachimg=2]
12 Days of Tools Giveaway
To Enter: use this link to view the post or stories to repost
1. Share any 12 Days of Tools posts or stories on IG
2. Tag us @ultimatetools
Enter up to 24 times (1 share & tag on Instagram for each unique
story and/or post)
The giveaway ends Monday Dec 12th, 2022 at 11:59 PM PST. The winner will be
announced on December 13th on Instagram and contacted via direct message.
This giveaway is only open to residents of Canada (excluding Quebec) over the
age of majority in their province of residence and is not sponsored, endorsed,
administered by, or associated with Instagram or Facebook. No purchase necessary.
Additional details can be found on our website
Cheers,
Xche
Today's Tool:
Whiteside 1/4" Up-cut Spiral Router Bit for $21.95 (29% Off)
Spiral bits provide a shear cutting edge that leaves a smoother cut than standard router bits.
The up-cut spiral design provides the best control with hand or table routing and when creating
dados this design brings chips up and out of the cut path for cleaner, cooler cuts.
Purchase Yours Here
Today's Tool:
Fine Tool Works 6pc MFT Bench Dog Pack for $85.95(25% Off)
Fine Tool Works precision milled anodized bench dogs are made for Festool MFT tables.
Each dog has a 8Mx1.25 internal threaded hole. The short and medium dogs have a
1" diameter shoulder that sits 5/8" or 3/8" proud. The shoulder has a flat face that can
be used as a reference or clamping surface for alignment.
Contains
- 2x 4" Long bench dogs
- 2x 5/8" proud bench dogs
- 2x 3/8" proud bench dogs
Get your 6pc MFT Bench Dog Set here.
Today's Tool:
Hultafors Talmeter 6m Tape Measure for $62.95 (25% Off)
Features a hard impact resistance ABS case that houses a white 25mm wide blade
with graduated scales. Unique among tape measures is it's 3 built-in scribes
that allow precise measurement and transfer of measurements either from;
the tape tip, front of case body or rear of case body. It also has a vertical
and diameter scale, and can create arcs.
Features
- 6m long
- 3 built-in scribes
- vertical & diameter scales
- replaceable tape
- quick release belt clip
Get your Hultafors Talmeter 6m Tape Measure here.
[attachimg=2]
Today's Tool:
Schwaiger Hand-Held Panel Carrier for $152.95 (35% Off)
Avoid injury and increase your productivity with a panel carrier.
Schwaiger's Hand-Held Panel Carrier features self-tightening rubber
jaws that securely grip and hold sheet material up to 65mm (2" 9/16) thick
and up to 70kg (154lbs). They easily slip over the vertical edge or top of a
panel and can be operated one-handed.
Get your Schwaiger Hand-Held Panel Carrier here.
Today's Tool:
FastCap's 1" Folding Pocket Chisel $36.95 (25% Off)
This chisel will be used more than any chisel in your tool arsenal. It's a
convenient and durable tool that you can quickly deploy, safely put away
in seconds and store in your pocket. The nylon handle is strong enough
to withstand hammering, while the Teflon coated blade prevents it from
rusting or getting "gunked-up".
Features:
- 1" wide blade
- Folding nylon handle
- Teflon coated blade
Get your FastCap 1" Folding Pocket Chisel here
Today's Tool:
Siasponge Soft Foam Abrasive Blocks for $1.50 each (29% Off)
Sia's 799s series soft polyurethane foam blocks are a versatile abrasive that conform to your
workpiece providing uniform pressure distribution. Measuring 69x98mm (2-3/4" x 3-5/8")
they fit comfortably in the hand. A flexible elastic binder allows the aluminum oxide abrasive
to bend and stretch around contours. They can be used for dry or wet sanding applications.
Get your Siasponge Soft Foam Abrasive Blocks here
Today's Tool:
Silky's Fine Tooth Tsubasa Saw for $49.94 each (30% Off)
The taper-ground Japanese blade cuts cleanly, quickly and with minimal effort.
The aluminum handle has a nice heft, providing a good handle to saw weight
balance and is clad in rubber for a comfortable and secure grip. The blade is
replaceable, and can be changed without tools. Includes a plastic protective sheath.
Features:
- 11.2" blade length
- 15.2 TPI
- Includes blade sheath
- Ergonomic rubber grip
- Made in Japan
Get your Silky's Fine Tooth Tsubasa Saw here
Today's Tool:
FastCap's 2P-10 Two Part Adhesive Solo Kit for $29.95 each (25% Off)
A 2 part adhesive that bonds materials together in 10 seconds. It's like a
cyanoacrylate (super glue) but it allows you to position your pieces before
locking them in place with the activator.
Get FastCap's 2P-10 Two Part Adhesive Solo Kit here
Today's Tool:
Kapro's 48" 905 Condor OptiVision Level for $76.95 (24% Off)
Kapro's 905 Condor series of levels are thoughtfully designed and built tough. The edges
of bubbles are highly visible even in low light situations. Vial liquids settle faster and are
UV resistant, so they won't fade over time. When checking plumb, a cut out provides clear
sight of the bubble.
Features:
- Accurate within +/- 0.5mm
- 48" long
- Continuous marking edge
- Oversized shock-absorbing rubber end caps
- Wall grip feature
Get your 48" 905 Condor OptiVision Level here.
Today's Tool:
WoodPeckers Woodworkers Edge Rule Sets (Metric or Imperial) for $99.95 (23% Off)
Edge rules simplify measuring and allow you to accurately measure the face and 1 side of your stock.
The short side is 3/8 inch wide while the long side is 3/4 inch wide. Whether you're measuring the
edge or the face of your stock, the corner of an edge rule always keeps you properly aligned.
Features:
- Imperial & Metric sets available
- 4pc Imperial set includes: 6", 12", 24" & 36" edge rules
- 4pc Metric set includes: 150mm, 300mm, 600mm & 900mm edge rules
- Anodized for durability
- Precision CNC milled
- Accurate to within +/- .003"
Get your WoodPeckers Woodworkers Edge Rule Sets here.
Today's Tool:
Hultafors 25" Adjustable Wrecking Bar for $141.95 (25% Off)
A versatile tool that excels at pulling nails and prying in confined spaces thanks to its
adjustable claw end. To improve leverage or make it more ergonomic for the user, the
claw angle can be locked in 9 different positions. The precision ground prying surfaces
distribute pressure evenly to minimize marring and dents, while the over molded anti-slip
rubber grip improves comfort.
Get your 25" Adjustable Wrecking Bar here.
