Updated Domino XL (and other new products) Info
Peter James
Some more Domino XL info...
- Cutter sizes will be 8mm ($50), 10mm ($52), 12mm ($54), and 14mm ($56).
- Looks like the 498590 ($65) cross stop (NOT the 493488) and trim stop 493487 ($58) will fit the XL as well.
- Festool will offer two different Domino XL assortment packages (one has 8mm and 10mm [$275] and the other has 12mm and 14mm [$250]).
- Festool will also offer Dominos in both Beech and SIPO
Sean is headed up to JLC Live, but will put up all new items on Festoolproducts.com tonight. I'll post the link as it's ready.
Regarding the SurFix - three different oils will be available.... Outdoor Oil, One Step Oil, and Heavy Duty Oil. They will come both in 5 liter canisters as well as refills. Festool is also releasing some Vlies pads for this as well. Hope this helps guys!
Beech Domino sizing...
14mm X 28mm X 750mm 18 count $65
14mm X 28mm X 140mm 70 count $50
14mm X 28mm X 100mm 80 count $50
12mm X 26mm X 750mm 22 count $65
12mm X 26mm X 140mm 90 count $50
12mm X 26mm X 100mm 100 count $50
10mm X 24mm X 750mm 28 count $65
10mm X 24mm X 100mm 120 count $50
10mm X 24mm X 80mm 150 count $50
8mm X 22mm X 750mm 36 count $65
8mm X 22mm X 100mm 150 count $50
8mm X 22mm X 80mm 190 count $50
Sipo Domino sizing...
14mm X 28mm X 750mm 18 count $95
12mm X 26mm X 750mm 22 count $95
10mm X 24mm X 750mm 28 count $95
8mm X 22mm X 750mm 36 count $95
Syslite looks AWESOME! It's going to be packaged with the Syslite, wall charger, car charger, and a bag - I would love to call this a sysbag lol! Dimensions are 6" X 4" X 3" and it weighs just under a pound and a half. Internal battery is a 7.2 volt 2.2Ah Li-Ion battery. Can run off of the internal battery, the provided wall or car charger, or even a Festool charger or battery. Two modes of lighting provide up to either 90 minutes or 4 hours per charge depending on the brightness mode.
The Surfix - interesting to say the least! A finish applicator set where the reservoir of finish is in the handle of the product. It will include the applicator, all three oils (heavy duty, one step, and outdoor), 5 replacement sponges, and 30 assorted abrasives all in a Systainer 3. Looks nice for even distribution of finish.
The handle is squeezable and finish flows into the attached sponge. All oils are Linseed-oil based as well.
They are sold in a .3 liter applicator ($35), a two pack of .3 liter refills ($30), and a 5 liter refill ($125).
Festool claims the one step oil is the best option for indoor low traffic surfaces, like furniture, shelving, and cabinets.
The heavy duty oil is the best solution for indoor higher traffic areas, such as stairs and dining tables.
The outdoor oil is best for, well, outdoor applications, such as garden furniture and decking.
The abrasives supplied are 6" abrasives. 20 Rubin and Brilliant sheets and 10 Vlies sheets.
Is it really 750mm or 75mm?
Any news on a systainer with dominos and cutters package like that available for the 500?
Tim, I've sent you a PM to help you out.
