- Jun 25, 2016
[size=18pt]Extend the limits of your Festool CSC SYS 50 cordless table saw with the TSO Extended Miter Gauge Fence Kit. Engineered for precision and versatility, this high-quality upgrade features T-slots on the back and top, making it easy to attach to the Festool miter gauge and permitting the use of accessories like stops, supports, and clamps for efficient, repeatable cuts. Each fence piece measures 1.94" tall and 11.81" long, offering robust support for cross-cutting tasks. The kit includes two fence pieces, connectors, and a dual-function Stop/Support assembly, allowing you to extend the fence length for better stability and performance with longer workpieces.
Shop TSO Extended Miter Fence
[size=18pt]Interested in adding even more capability to your Festool table saw? This Extended Miter Fence is available as part of our Festool CSC SYS 50 EB Cordless Table Saw Upgrade Kit, which also includes a pair of JessEm Stock Guides (and TSO-made custom mounting brackets for them), a TSO blue Systainer3 M112 enclosure, and a custom CNC-cut foam insert.
Here's a few of our latest products:
JUST RELEASED! MFT/3 Router Table Extension
Simplify your workflow with a router table extension purpose-built for the MFT/3. The flush-fitting design enables you to use the large work surface of the Festool MFT/3 as router infeed/outfeed support, helping you maximize your workspace and productivity. Compatible with the most popular trim routers on the market.
JUST RELEASED! MFT/3 Extension Table
Expand your Festool MFT/3 work surface by 33%! This extension utilizes three precision machined brackets that quickly lock into the MFT/3 perimeter extrusions to provide a rigid, seamless extension of your worktop. The MDF top is CNC-machined and shares the same 20x96mm hole pattern as the MFT/3, ensuring compatibility with all of your workholding accessories.
GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
