tjbnwi
- May 12, 2008
extiger said:The Romex running to my undercabinet lights in the kitchen is 12 gauge. And in the service panel, there are 2 20-amp circuit breakers. This doesn't include the large 220v breaker for the oven. So, I am in business.
Not necessarily, if the manufacture instructions for the machine require a separate 20 amp circuit for their unit, you cannot use the existing. The manufactures instructions override the code requirements. The UL approval is dependent on their instructions being followed. The NEC requires all electrical items to be "listed", violate their instructions and it is no longer a listed item. Your insurance company may not cover a loss if it is caused by the machine being installed improperly.
Are the under cabinet lights wall switched? If so you would not want to use that wiring.
I don't mean to come off as an a$$, just don't want you to have an issue latter.
