Unless you're planning on using Qwas dogs to set up rails and cut perfect 90 degree cuts, just drill 3/4" or 13/16" holes wherever you need them for clamps. If you don't get the hole pattern absolutely, perfectly square, having 20mm holes at 96mm centers is worthless.
