I just bought a used CT22 ($250) and have a couple questions.
1) I want to put a Onieda Dust Deputy (separator) before it. The only way to avoid some hard angles and a lot of extra hose is to mount the CT22 above the dust deputy with the hose of the CT22 pointing straight down. Any reason that wouldn't work? There will be almost nothing coming though, if past experience is any guide; the separator is very effective with little suction loss.
2) Since there will be almost nothing but really fine stuff, maybe I could just take the bag out and just use the final filter? Would that make it suck better? Other then possibly clogging before it should (which I can find out by trying it) is there any reason not to try it that way?
3) Is there any advantage to running a 2.25" hose from the dust deputy to the CT22? it will only be a couple feet long and carry only fines.
4) The CT22 won't be where I will be plugging tools in. Can I run an extension cord from the CT22 outlet to an electrical outlet(connecting the end of the extension cord to the receptacles in an electrical box), plug the tools into the electrical outlet, and have the CT22 work on automatic? Any alternate ways to make this work?
