I needed to recess some screw heads to attach a nightstand top to the frame. I could have routed them, but thought I'd try using the Domino. I used an 8mm and 5 mm bit. I used a wood block to limit the plunge of the 8mm bit to about 6mm. Then I plunged the 5mm through. This worked great. Setup time was quick too.
