TSO Products said:I have heard of some tradespeople using shorter (cut off?) guiderails when dealing with jobs involving short cuts.
what experience should be kept in mind when cutting down a track?
What works - and what doesn't?
Hans
TSO Products said:Peter : what would be a good length to cut to for all-around use ?
Hans
PS: yes WD-40 works great to keep the aluminum from sticking to the blade even in an industrial size application but dri lube stick works "clean"
TSO Products said:actually Iam trying to get a reading on customers experience for development of a new accessory. For that reason we are interested in the view from "outside" our own shop and needs [smile]
Hans
TSO Products said:thanks for all the input!
what got this thread started was a comment from a user that the Square tilts a very short track when no saw is resting on it. I know it had to be shorter than the 42 inch FS 1080 because it stays put without support. So what is everyone using for a homemade "short"track?
To create the option for an add-on "Short Track Support" we included a 10-32 tapped through hole in the latest production toolssee our prototype picture attached.
Now the question: is it really needed?
Hans
Michael Kellough said:Hans, what product is "dri lube stick"?
I guess the biggest thing you'd want to cut with a short rail would be a 2x12.
With 55 saw that will be near full depth with a Combination blade so double the gib spacing and add 11.5".
With a 75 saw you won't need full plunge depth so you don't need to double the full gib distance.
With construction grade lumber we don't have to be so picky about the cut quality so the rail could be shorter on the far end. Just make sure you can get full plunge depth (for the stock thickness) before entering the wood, especially if you're steadying the wood with one hand.
Michael Kellough said:Here's a product suggestion Hans (maybe something you have in mind with this question); it would be great to have an attachment to the GRS-16 that would hold the guide rail snug to a board.
Or maybe just a spring loaded (slippery) bumper that fits (tightens) in the channel under the rail.
You would lower the far end of the very short rail over the board and pull back against the spring enough so the GRS can fit over the front of the board. Then just bump the rail left or right to the mark (that's why the bumper needs to be slippery) and cut, hopefully without having to hold onto the board.
Something like that attached to this system would be pretty great.
TSO Products said:Dri Lube stick source for aluminum cuttinghttp://www.mscdirect.com/product/details/57810087?rItem=57810087 about $ 20
I used a product like that for cutting on finished product where cleanliness was critical. A little goes a long way. works for tapping, drilling, bandsawing etc
Hans
