So if it's such a good "grinder" than why not make an arbored interface instead of only being able to use the very delicate velcro pads?
I'd much rather use this with the thick resin 24 or 36grit sanding discs I now use on my grinder.
That way you'd have no issue at all with worrying about the velcro pad. Nobody's ever accused the fastfix pads of being durable...
I actually thought the RAS did have a grinder-like pad interface, was disappointed to here it did not. Darn shame it doesn't.
JT
Probably because it is not a good grinder. While it can do many things a grinder can do it's slower speed would cause anyone trying to use it with grinding wheels to just bear down on it. The Velcro probably is the Achilles heel of this tool,but only if you are to rigid to accept the fact you cannot use it exactly like an angle grinder but more like a sander which, of course, it is. One of the things that makes the dust control as good as it is is the fact it is not traveling at grinder speeds. That would impart too much velocity to the debris coming off the disk.
