Vac-Sys two head operation
georgenash
I if I want to operate the two heads I have independantly. The obvious question is if I release the pressure of one head will it release the pressure from the other , both being operated from the same pump?
You should be able to install a pair of valves to the lines. Turn off the valve to the cup you what to keep suction on. Press the foot valve to release the suction on the cup you want your work release. Etc.... lot of messing around. Sounds like you probably should get a pair of set 1’s
Rick.
