VAC-SYS
Demetrius
Hi everyone,
Has anyone in NAINA purchased the VAC-SYS from EUROPE and brought it over?  How much did it cost? And are you happy with it?
Demetrius
I've looked into the vac-sys and decided against getting it. I recently purchased a vacuum pump that has the continuous cycle mode that you need for vacuum clamping as well as an auto cycle mode for veneer pressing so I will just use that if needs be.
The vac sys is only available in 230V so that is something else to consider.
