This is my working prototype #1 of my Vac Sys I designed and built. Other than the CNC cut Russian birch every component is off the shelf so it assembles very easy and cheaply the most expensive part is the pneumatic valve and detent pins at around $16. It can be used on top of bench as shown or side mounted. It tilts 180° and rotates 360° I used a series of detents instead of the twist knobs that Festool uses to help with carpel tunnel issues. I prefer just pulling out the detent pin and letting it pop back in where I want it. Both can be locked in at 30° intervals but truthfully I think this might even be overkill. Every 45° of even 90° might be better. I guess this would depend on how you use it but My plan is mostly edge banding work so horizontal and vertical are really all I use. The upper and lower supports are fully mortised into the sides. As of right now there isnt even any wood glue holding it together and its solid. Not sure how much weight it will handle but I can lift my bench up by the clamped piece so I have no worries about it holding anything I ask of it.
