Hi TK,
I have had the smaller version, the CT11E from new in 2002. The motor & upper casing is the same as the CT22....It still works fine and I have never had anything mechanically go wrong with it.
However, when I first got it, it did'nt come with the Hose Garage on top, so I purchased one as an accessory about 8 years ago. Whatever the Hose Garage plastic is made from is most certainly not the same as the plastic the CT is made from. It is so flimsy and brittle and has huge cracks in it and bits broken off it now.
I believe this is a problem known to Festool but I'm not sure if the manufacturing material or process has now been changed...?
I'm tempted to replace my garage, but not if they are still using the same type of plastic.....
I also have a couple of CT26's and a Midi, albeit newer but no issues with the built in Hose Garage's on those.
