- Jul 25, 2022
Vacuum Hose Clips For Festool 27mm & 36mm Dust Extraction Hoses - Set of 8
27mm or Bosch VAC005:https://www.amazon.com/dp/B0C5W1MJ1D
36mm:https://www.amazon.com/dp/B0C5W1D672
- PERFECT: Holds your power cable tight against your dust extraction hose for safety and simplicity
- COMPATIBILITY: These hose clips are compatible with Festool 27mm ribbed or smooth, Bosch VAC005 or the Festool 36mm hoses
- MATCHED: Modeled to fit the contours of your hose and manufactured with flexible material, these hose clips won't pop off like the others
- SET: 8 hose clips for your 27mm dust collection hose are included
- Designed & Made in Charlotte, NC - USA
