I tried the round wood blade(500139) on my brand new Vecturo to attempt a long vertical cut through plywood subfloor under a toe kick. I was unable to cut 2" without being enveloped in a cloud of smoke. I tried very shallow cuts and tried setting the speed on 1. I got less smoke but I could never get it to cut without smoke. The smoke made it impossible to stay in the room. Festool says this about the 500139: "Use for long, straight cuts, or for making cut-outs in installed flooring." I thought that was exactly what I was doing.
I need to make a flush or near flush cut, about 16 feet long, through 18mm plywood, along a toe kick without damaging the toe kick board. I have 3-4" of vertical clearance under the toe kick. Am I using the wrong blade or the wrong tool altogether? I'm pretty disappointed in the performance and I hope somebody has a better suggestion.
This is what I envisioned. My picture would have looked just like this, except with a billowing cloud of smoke coming from around the blade and nearly obscuring the Vecturo. That probably wouldn't have been as good for marketing purposes though.
