Shane Holland said:
especially in conjunction with the festool OS-AH addon?your blades may be slightly offset from center when using this adapter, but this will not affect functionality
If you're upgrading get the multimaster 350 then. Cuts much faster than the old 250 , less vibration & less noise.p532 said:Thanks everyone for the information. This weekend I had a friend help me with a project. He refused to take any money but when I offered him my MultiMaster FMM250Q he could not refuse. Now it's time for me to upgrade.
Spiff said:Be aware that the Multimaster 350 comes in two versions currently! The old, sell-through one, the 350Q and the new 350QSL. The difference is in the blade attachment. The Q had a quick release pin lock and the new QSL does away with that and has a quick release snap fit which is better. Google Youtube for video demos.
UK members who are quick can pick up a 350QSL MM kit with a whole bunch of blades included, all for £190 in the Black Friday sales at Miles Tool & Machinery in the UK (I have no connection or interest)
BTW - General Question: [scratch chin]
Can anyone confirm that the new Fein Multimaster 350QSL fully fits the Festool depth stop and positioning aids? I've seen various comments but I'm unclear if:
1) the collars are the same size, or if a shim is required for the Fein?
2) normal articulation is restricted in any way?
3) if there's a gap between the base magnet and blade when it's mounted up on the new QSL snap mount
Advice gratefully received if anyone has a definitive answer before I place an order!! [not worthy]
Glad I could be of help.p532 said:Harry, thank you for detailed explanation and pictures of the Starlock incomparability.
This was very helpful to me.
harry_mc said:Jim, I believe the Starlock blades are backwards compatible with the older Multimaster quick-in mounts (and several others), so no adapter is needed.
harry_mc said:The finished product works well, but requires one of two Fein blades, neither of which seem to be available in the USA currently, but did come with my AFSC 18v wood kit: blades 201 and 203. Because these blades only fit the Supercut due to the Starlockmax mount, this doesn't appear to be an option for the Multimaster QSL.p532 said:Harry, thank you for detailed explanation and pictures of the Starlock incomparability.
I'll have to either order blades from the UK or see if they can be ordered here.
harry_mc said:Hi Magpal,
The issue with the blades is finding blades as long as the Festool base that also have the proper offset 'bend' to be parallel with the base's plunge tubes. Bosch makes a long enough blade, but it doesn't have the offset required to be parallel with the base. There may be other blades out there, but I did not see them at the time.
Thanks, Harry
Sent from my iPhone using Tapatalk Pro
