If I had to complain about the vs system, that would be high on the list. I have very little control reguarding how much material I have left under the slots. I am using 15mm ply stock. For the small dt jig the optimum size suggested is 18mm according to the chart. In set up you set the cut a 12mm but to get the joint tight I went .5mm and tried it again. Still a little loose I went another .5mm. The joint was just about perfect reguarding tightness but left me with very little mareial under the slot and that open between the pin and slot.
I have no idea how this gap can occur as I obviouly have to cut both components at the same time on the same jig. The problem is very consistant and the vs600 works with a rub collar that prevents lift off.
Shane, if you are out there, can you ask our hairy armed guru if he has any ideas, please. This is not a question that can wait until the last week of April in Indy to answere. Though it is a good selling point for the advanced router class. [big grin]
