I want to strip several layers of household lead paint off complex wood casing trim (douglas fir). I'm thinking of shaping an LS 130 sanding block to match trim profile. Lead abatement practice suggests wet sanding with a HEPA vacuum so I'd spray down the surface regularly with a spray bottle and connect the linear sander to a CT 26 HEPA vacuum. Is wet sanding necessary when this sander hooked up to a HEPA vac or can I do it dry?
Assuming wet sanding is recommended, I understand one removes the HEPA filter from the vacuum when running in wet mode which would defeat the purpose so I'd instead have to operate in the vacuum's dry mode even though I'm lightly spraying down the surface. Would the moisture I'm adding cause clogging either on the sanding pad or prematurely clog the vacuum bag?
I can't find instructions to customize sanding block on Festool's site (http://www.festoolusa.com/products/sanders/profiles/doityourself-kit-490780.html)--can someone point me to directions?
How do the adhesive holes line up with the block holes after one has altered the profile--it seems that the more creases one cuts into the sanding block, the closer together the sanding paper holes will be pulled...if they don't line up, the vacuum won't work?
How might I shape the sanding block precisely and how precise does it need to be?
I'm thinking of starting with Cristal P40 or P60, moving onto Cristal P80 or P120, and finishing with Rubin P150 or P180. Any suggestions?
Is it recommended to instead use an infra-red heater to safely strip the bulk of the paint and then use a sander to remove residue?
