What Brass Template Size OF 1010
Peter Parfitt has a video showing his use of the Whiteside 9500 inlay kit with its brass bearing-fitting it to the OF1010. It was a tiny bit too tight so he filed it on a drill press for a second or two. Works a treat. It produces a great tight fitting inlay kit if you're considering it at some stage.
Thanks. I went with the 3/16. I only got two sizes to start, for about $15 I'm thrilled with what I've got. If things change in the future I won't be out much and can invest in something a little more flexible like you guys mentioned.
