What comes with the 500869 conturo table?
zachjowi
Wisconsin
I saw a video that showed the contents being the table top, (500175) Table Insert Bracket, plastic guide plates, and stabilizers.  Do you need to buy the MFT/3 table separately then retro it?  I also see I can buy the table top, inert, guides, and stabilizers all separately.
The 500869 comes with the MFT frame and the Conturo perforated top & all the hardware, Including leg braces.
The 500175 is just the hardware, no Conturo perforated top.( Allows you to make your own top to fit in your own bench...)
The 500366 is the Conturo perforated top on it's own.
Hope this helps.
I bought the 500175 and made a top for it. I actually just cut my diy mft workbench top into 3rd's and the center section comes out for when I need the conturo mount.  I didnt make the section the full size of a regular MFT. I ended up shrinking it down some.  I really only use it for small/narrow pieces.  Larger stuff I prefer to take the conturo to the part.  I dont use my mft bench for cutting only clamping so I dont care if the dog holes are super precise.  The 500175 does come with a paper template if you want to make your own.
